Only failure which can occur is of formwork system.
Today using aluminium formwork or using engineered formwork like Doka Walls are casted up to height of 5 meters.
The only this is that, formwork should take all the freshly poured concrete pressure.
I did casting of wall up to height of 4.2 meter, if formwork can take load and keeps its alignment under pressure, there is nothing to worry about.
best way to do it is fill the concrete in wall in layers of 1 meters approx continuously, after each layer and during pouring keep watch on Formwork to avoid accidents.
