By:
By:
Advanced…
    New posts Search forums
What's new
By:
By:
Advanced…
  • Search forums
  • LOUNGE
  • MCQ Questions
  • Reinforced Concrete - MCQ
1400 kg/cm2 respectively and the modular ratio is 18, the percentage area At of the steel required for an economic section, is
  • Thread starter Thread starter Srinivasan
  • Start date Start date Jan 30, 2018
Srinivasan
Srinivasan
Prime CE
mumbai
  • Jan 30, 2018
(A) 0.496 %
(B) 0.596 %
(C) 0.696 %
(D) 0.796 %
The correct Answer Is
(C) 0.696 %
Srinivasan
If permissible working stresses in steel and concrete are respectively 1400 kg/cm2 and 80 kg/cm2 and modular ratio is 18, in a beam reinforced in
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
[A + (m - 1)ASC] known as equivalent concrete area of R.C.C. is given by
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
The maximum ratio of span to depth of a cantilever slab, is
  • Srinivasan
  • Feb 9, 2018
Jun 6, 2019
Ayuba
Ayuba
Srinivasan
An R.C.C. roof slab is designed as a two way slab if
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
A short column 20 cm × 20 cm in section is reinforced with 4 bars whose area of cross section is 20 sq. cm. If permissible compressive stresses in
  • Srinivasan
  • Feb 8, 2018
Feb 8, 2018
Srinivasan
Srinivasan
