yes sir exactly, But I want Basic Format in which Include Parts required to make window Such as bearing, vertical section, top section, glass, sealant etc.
Mainly Mentioned what is the name base section of window
At first you tell me the vertical and horizontal section no and which brand you want to use.
Then you collect the unit weight of each and every sections.Joint angle ,L angle etc
Then Rmt X unit weight ,you can easily find the total weight of that section.
