Check List For Box type Waterproofing Works
Checklist for box type waterproofing work consist of following points;
Box type waterproofing on Horizontal Surface
  • Is PCC done to required depth and level and cleaned before application of base coat
  • Is base coat done of required cement mortar mix with approved water proofing compound
  • Shahabad tiles of approved thickness and cut with sides straight used
  • Is grouting done with cement slurry of required consistency till no further absorption takes place
  • Are joints filled with cement mortar of approved mix
  • Is final layer of cement mortar of approved mix provided to required thickness
  • Is curing carried out by flooding for 7 days
Box type water proofing on vertical surface
  • Is surface cleaned and wetted
  • Are Shahabad tiles of approved thickness and cut with sides straight used
  • Are Shahabad tiles fixed on pardi in line and level and upto 1mt height at a time
  • Is it done upto 18” above ground level or as per drawing
  • Are joints sealed with cement mortar of the approved mix
  • Is grouting done with cement slurry mixed with approved water proofing compound till no further absorption by tiles takes place
  • Is sprinkling done for 3-4 days
  • Is final layer of water proofing plaster done as per approved mix and thickness
checklist is a important record it helps us in order to get work done correctly and it ensure we do not miss any point to check which is important from aspect of Quality of work.
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed check list for box type water proofing
  • Box Type waterproofing.doc
