listed below are the requirements of good building stones:
(i) Strength:
it should be able to resist the load coming on it. Ordinarily this is not of primary concern
since all stones are having good strength. However in case of large structure, it may be necessary to check the strength.
(ii) Durability:
Stones selected should be capable of resisting adverse effects of natural forces like wind, rain and heat.
(iii) Hardness:
The stone used in floors and pavements able to resist abrasive forces caused by movement of men and materials over them.
(iv) Toughness:
Building stones should be tough enough to sustain stresses developed due to vibrations. The vibrations may be due to the machinery mounted on it or due to the loads moving over on the stones.. The stone aggregates used in the road constructions should be tough.
(v) Specific Gravity:
Heavier variety of stones should be used for the construction of dams, retaining walls, docks and harbours. The specific gravity should be in between 2.4. to 2.8.
(vi) Porosity and Absorption:
Building stone should not be porous. in porous stones rain water enters into the pour and reacts with stone and crumbles it. In higher altitudes, the freezing of water in pores takes place and it results into the disintegration of the stone.
(vii) Dressing:
Giving required shape to the stone is called dressing. It should be easy to dress so that the cost of dressing is reduced. However the care should be taken so that, this is not be at the cost of the required strength and the durability.
(viii) Appearance:
In case of the stones to be used for facade works, the appearance is a primary requirement, its colour and ability to receive polish is an important factor.
(ix) Seasoning:
Good stones should be free from the quarry sap. Laterite stones should not be used for 6 to 12 months after quarrying. They are allowed to get rid of quarry sap by the action of nature. This process of removing quarry sap is called seasoning.
(x) Cost:
Cost is an important consideration in selecting a building material. Proximity of the quarry to building site brings down the cost of transportation and hence the cost of stones comes night come down..
