Check List For Fire Protection Installation
Check List For Fire Protection Installation consist of following points;
1.0 Piping Works
1.1 Specification for Pipes & Fittings
1.2 Piping Layout (Drawing Ref. No. )
1.3 External Piping's
  • Pipe Size, Make and Specs
  • Court Yard Hydrants Layouts & Piping Work
  • Protective Treatment to Piping
  • Pressure Testing of Pipes
  • Vertical Stand-posts
  • Hydrant Valves, Heights, Specs
  • Hose Reel Boxes
  • Painting
1.4 Wet Risers / Sprinkler Riser
  • Supporting Arrangement
  • Painting of Support
  • Piping Works & Clamping Details
  • Pressure Testing
  • Twin Hydrant at Floors
  • Hose and Boxes
  • Sprinkler Branch Piping
  • Pressure Testing
  • Sprinkler Head Framing
  • (False Ceiling Work)
  • Painting
2.0 Equipment
2.1 Main Fire Pump
  • Make, Capacity, Head, Specs.
  • Installation and Operation
2.2 Sprinkler Pump
2.3 Jockey Pumps
2.4 Booster Pumps
2.5 All Piping as per Specs
2.6 Fire Pump Panel
  • Hooter / Siren
3.0 Complete Installation
4.0 Fire Alarm System
  • Make, Specs. Of Panel
  • Cabling
  • Installation & Operation
  • Testing
  • Main Fire Alarm Panel
  • Repeater Panel
  • All Hooter Working
  • Manual Call Points
5.0 Fire Brigade Inlet Connection
6.0 CFO’s Approval to Fire Fighting System
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed check list for fire protection system
  • Check List For Fire Protection Installation.doc
Reactions: Anant Mishra
