Check List for Fixing of Flush Door Shutters
Check List for Fixing of Flush Door Shutters consist of following points;
General
  • Type of Flush door shutter
  • Location (Kitchen/Bedroom/Toilet)
  • Dimension & Squareness
  • Surface of door shutters Free from Defects (Bulging, Cracks, Barer Holes, waviness etc.)
Pre-work
  • Line and Level of Door frames
Fixing
  • Fixing of Lipping patti
  • Fixing of Hinges
  • Line, Level Verticality
  • Equal nominal gap b/w door shutter and frames
  • Fittings as per drawing (Handles / Locks / Aldrop / Tower bolt / safety chain / Eyepiece / Baby Latch / Stopper / eye piece / Tad Patti etc).
Finishing
  • Primer Application
  • Putty Application
  • Painting / Polishing
  • Undulations shall not be visible after painting
  • Any Other –1
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed Check List for Fixing of Flush Door Shutters
  • Check List for Fixing of Flush Door Shutters.doc
Reactions: Anant Mishra
