Check List For Construction of Asphalt / Concrete / Paver Block Roads
Check List For Construction of Asphalt / Concrete / Paver Block Roads consist of following points;
  1. Setting Out and Survey
    • Survey Drawings available
    • Pegs from the Reference Point
    • Levels Marked with respect to TBM
  2. Excavation
    • Cut off Level
    • Filling Required
  3. Compaction of filling
  4. Sub-Grade Preparation
  5. Kerbing in Level and Alignment
  6. Storm Water Drain if any
  7. Provision for Drain Line Inspection Chambers or Cables if any
  8. Underground services provided
  9. Sub-base compaction
  10. Base Course Compaction
  11. Asphalting
    • Base Course Cleaning
    • Temperature
    • Thickness
    • Rolling / Compaction
    • Gradient
    • Final Levels
    • Speed Breakers
    • Road Markings
  12. Concreting / paving blocks
    • Thickness
    • Grade
    • Compaction
    • Construction or Expansion Joint
    • Form Work Alignment
    • Compaction of Concrete
    • Final Road Level
    • Gradient of Road
    • Road markings
  13. Cleaning
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed check list for internal road work
  • Checklist for Construction of Roads.doc
Reactions: Anant Mishra
