Check List for Wood Joinery Works
Check List for Wood Joinery consist of following points;
Specification
  • Type of Timber
  • Size of Timber Section
  • Pre-treatment
  • Free from Defects (Knots, Cracks, Barer holes)
Joinery
  • Fabrication, Size of Frame
  • Rigidity at Joint Pins
  • Right Angles
  • Anti-termite Preservatives
  • Bracing's
  • Primer
Erection
  • Location
  • Hold-fasts – Size / Nos.
  • Level, Vertically
  • Bracing's
Finishing
  • Surface Finishing
  • Primer
  • Painting / Polishing
  • Architraves
  • Undulations shall not be visible after painting
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed Check List for Wood Joinery Works
  • Check List For Wood Joinery Works.doc
