Bitumen Penetration Test
Penetration test is the most common test to grade bitumen according to its hardness and consistency. It determines the softness or hardness of a sample of bitumen by measuring how deep a certain needle can penetrate the bitumen under controlled test conditions. Penetration test is an essential test in road construction, where the appropriate grade of bitumen will result in long-lasting, weather-resistant roads.
Every step of the penetration test process—preparation to result—in simple language and clear steps.
Purpose of the Penetration Test
Bitumen: A Quick Background
Apparatus Needed
For conducting the test for penetration, the following apparatus are required:
After the sample is prepared, the test agent for penetration is conducted as follows:
The method complies with IS 1203:1978, which prescribes standardized procedures for penetration test on bitumen.
Precautions to Ensure Accuracy
Penetration test is an essential step in controlling the quality of bitumen. Based on how deep a needle penetrates a sample of bitumen under test conditions, engineers can quickly decide whether the bitumen in question is well-suited to various environmental and construction requirements. It's easy, quick, and very enlightening when conducted with care.
- The primary objective is to find out the grade of bitumen based on its consistency measure.
- It assists engineers in choosing appropriate bitumen for various climates and pavement types.
- Soft bitumen indicates higher penetration, whereas harder bitumen means lower penetration.
- Bitumen is a sticky, black product resulting from crude oil refining.
- Based on the method of refining (distillation, solvent extraction, etc.), bitumen may differ in hardness and temperature characteristics.
- Good quality bitumen must:
- Not soften in warm climates.
- Not become brittle in cold climates.
- Have the correct viscosity during compaction and mixing.
Apparatus Needed
- Penetrometer – Standard needle assembly and dial gauge come with it.
- Standard Needle – Carefully sized (generally 1 mm diameter) and has a weight of 100 g along with the loading device.
- Metal Container – To store the molten bitumen sample.
- Water Bath – Keeps test temperature at 25°C.
- Thermometer – For testing water bath temperature.
- Benzene – For cleaning the needle after every trial.
- Heat the bitumen until its pouring consistency (above the softening point).
- Stir well to eliminate any air bubbles.
- Pour into a metal container, with the bitumen depth being not less than 15 mm greater than the anticipated penetration.
- Condition the sample at room temperature for 90 minutes.
- Prepare a water bath at 25°C and leave it for another 90 minutes for equitable conditioning.
- Position the container holding the bitumen sample beneath the needle of the penetrometer.
- Start lowering the needle until it is lightly touching the surface of the bitumen.
- Adjust the dial gauge to zero or note the original reading.
- Let go of the needle and allow it to penetrate for a precise 5 seconds.
- Observe the last dial reading, which is the depth of penetration in tenths of a millimeter.
- Test three times, at least 10 mm apart, on the same test piece.
- Clean the needle with benzene between trials.
- Compute the mean of the three readings – this is the ultimate penetration value.
- Unit of measurement is tenths of a millimeter. Therefore, a reading of 65 represents penetration of 6.5 mm.
- Example Grades:
- 30/40 grade → 3.0 to 4.0 mm penetration
- 80/100 grade → 8.0 to 10.0 mm penetration
- Increased penetration → softer bitumen (used in cold climate)
- LOWER penetration → harder bitumen (used in hot climate)
- The sample should be dust-free or free from impurities.
- The container should not be agitated during the test.
- The needle should be washed and dried before taking every reading.
- Proper temperature (25°C) and precise needle weight are essential.
- Don't apply this test to soft materials such as tar or cutbacks – they are subjected to viscosity tests.
- In warm climates, lower penetration value (30/40) bitumen is utilized to prevent melting.
- Whereas in cold climates, more penetration grade (180/200) is used to avoid brittleness cracking.
- For spray use, high penetration bitumen is utilized.
