Construction Defects in buildings
in the attached presentation we cover the following:
lobvious exapmples of defect cracked, damaged detoriatede brick work.
•Determination of actual defect requires a professional inspection to find the cause of the problem and to provide the right information for remedial works.
Design Deficiencies
Material Deficiencies:
Substandard Workmanship
Subsurface or Geo-technical Problems
Dampness
•Seriously Damped Roof
Roof Crack and other areas
(image courtesy google and various project sites)
  • concrete crack defects revised.pdf
Reactions: HockeyPuck
Design Deficiencies
Dampness
Srinivasan article discusses a lot about cracks in concrete. One of the tools that I think that all construction engineers should have on-board with them is a Crack Comparator. It is basically a wallet-sized clear plastic card that has graduated scales (Metric & English) that allow you to put on top of the crack and measure its width. This is very handy & inexpensive tool for assessing the type & severity of the crack you are dealing with. Look it up on the Web and purchase one for yourself and the people on your crew - Cheers!!!
