Cube test for PCC 1:2:4
If you look at the grade then confirmation is only done by doing a cube test.
Normally cube testing is not done for PCC (Plain cement concrete) as its laid only for making level surface.
If the PCC is to be done for other than ground leveling or filling purpose, you can do cube testing.
