Standard Heights of Fittings in The Residential Buildings
For Main Door from Inside
Name of Fitting - Recommended height from FFl - Position of Fitting
Tower bolt 15 cm (6") - Top flush to top of shutter - 5 cm (2") from opening edge of shutter.
Safety chain - 145 cm (58") - 5 cm (2") from opening edge of shutter.
Eye piece - 145 cm (58") - at centre of shutter.
Handle'D' type (bottom) - 120 cm (48") - 6.5 cm (2 1/2") from opening edge of shutter.
Night Iatch - 100 cm (40") - at opening edge of shutter.
Tadi patti - 85 cm (34") - at the opening edge.
Rubber gattu - 7.5 cm (3") - 7.5 cm (3") from opening edge of the shutter.
For Main Door from outside
Unit number plate - 175 cm (70") - centre of shutter.
Name plate - 167.5 cm (67") - centre of shutter.
Decorative handle (bottom) - 110 cm (44") - 7.5 cm (3") from opening side edge of shutter.
Aldrop - 90 cm (36") - At the opening edge.
Door stopper - as per requirement - At the opening edge.
For Internal Door from Inside
Handle'D' type (bottom) - 95 cm (38") - 6.5 cm (2 1/2") from opening edge of shutter.
Baby Iatch - 82.5 cm (33") - at opening edge of shutter.
For Internal Door from outside
Handle'D' type (bottom) - 95 cm (38") - 7.5 cm (3") from opening edge.
Tadi patti - 85 cm (34") - at opening edge.
Door stopper - as per requirement - 5.0 cm (2") at opening edge.
For WC Bath Door from Inside
Hook - 160 cm (64") - at centre of shutters.
Handle bottom - 95 cm (38") - 7.5 cm (3") from opening edge.
Standard Heights of Plumbing Fittings from FFL
Tumbler cock = 30 cm (12")
Bucket cock = 75 cm (30")
Mixing arrangement 4 way divertor = 75 cm (30") up to center of mixer/divertor.
Shower = 195 cm (78")
Wash Basin = 82.5 cm (33") upto top of rim.
High level cistern = 125 cm (50") between top of pan and upper side of cistern
Low level cistern = 30 cm (12") between top of pan and upper side of cistern
Urinal = 65 cm (26") upto top of bowl.
Soap dish = 90 cm (36") top of soap dish.
Stop-cock for wash hand basin = 30 cm (12") from finished floor level (F.F.L)
Kitchen bibcock = 20 cm (8") from kitchen otta top or 100 cm (40") from F.F.L.
Standard Heights of Electrical Fittings from FFL
Wall light point = 230 cm (90")
Ceiling point = centre of the room as per architectural drawing
Bottom of switch board with light, fan, switches regulators, 5 amp. socket = 135 cm (54")
Plug point, T.V. and telephone point in living room. = 45 cm (18")
Standard Heights of Electrical Points
Angle holder (bracket point) = 2.25m (7'6") from F.F.L.
Fan point = On ceiling, centrally at diagonals crossing of rooms Switch board = 1.35m (4'6") from F.F.L.
T.V. / Telephone and 5 Amp. point = 0.60m (2'0") from F.F.L.
Bell push = 1.35m (4'6") from F.F.L.
D.B. (distribution dox) = Above the entrance door or in passage = 2.40m (8'0") from F.F.L.
Power point in bath = 1.5m (5'0") from F.F.L.
