Different brands of cements
Hi All,
We have been using Ultratech cement for OPC and PPC. Is it ok to look at other brands like Coromandal etc and what are the factors to keep in mind while selecting other brands. Thanks in advance for your valuable suggestions.
Reactions: akash malakar
Hi All,
Dear,
There are various brands of cements manufacture in India. But the availability of cement brand depends upon on the state or country locations. In India approximate 130 companies of cement manufacturing. some of common as below:
1) ACC
2) JSW
3) RELIANCE
4) ACC
5) ULTRATECH
6) CORROMANDAL
7) BIRLA A1 PLUS
8) ZUARI
9) WONDER
10) PENNA
11) ORIENT
12) NIRMA
13) KESORAM
14) JINDAL
15) HEBBAL
16) CHETTINAD
17) JAYPEE
18) HATHI
19) AMBUJA
20) LAFARGE
21) J.K CEMENT
Factors to keep in mind while selecting other brands are below:
Selection of cement based on suitability for different concrete construction is important for durability considerations of structures. Thus, making wise choice of cement type for particular construction site, prevents structure from deteriorating and saves much repair and rehabilitation cost later. Functional requirement of the structure, design parameters, speed of construction, durability characteristics, environmental condition are some of the major factors which affect selection of cement for appropriate application and intended use.
Following are the suitability of various cements for different environmental conditions:
1) Applications of 33 Grade Ordinary Portland Cement (OPC)
It is used for normal grade of concrete up to M-20, plastering, flooring, grouting of cable ducts in PSC works etc. The fineness should be between 225 and 280.
2) Application of 43 Grade Ordinary Portland cement (OPC)
  • It is the most widely used general purpose cement. For concrete grades up to M-30, precast elements.
  • For marine structures but C3A should be between 5 – 8%.
3) Application of 53 Grade OPC Cement
  • For concrete grade higher than M-30, prestressed concrete works, bridge, roads, multi-storied buildings etc.
  • For use in cold weather concreting.
4) Applications of Portland Slag Cement (PSC)
It is OPC + granulated slag cement. It gives low heat of hydration. The slag should be more than 50%and up to 70%. It is used for;
  • Marine and off shore structures- very high chloride and sulphate resistant.
  • Sewage disposal treatments works
  • Water treatment plants
  • Constructions which are expected to be attacked by dissolved chlorides and sulphate ions.
  • Should be mainly used for all future structures.
5) Applications of Portland Pozzolana Cement
IS: 1489(part-I ) -1991 (using fly ash). It gives low heat of hydration and reduces the leaching of calcium hydroxide. This cement should be used only after proper evaluation. This should be tested as per IS: 1489 (Pt I) – 1991. It is used for:
  • hydraulic structures-dams, retaining walls
  • Marine structures
  • Mass concrete works- like bridge footings
  • under aggressive conditions
  • Masonry mortar and plastering.
6) Applications of Sulphate Resisting Cement
(C3A < 3%) Sulphate Resisting Portland Cement is a type of Portland Cement in which the amount of tricalcium aluminate (C3A) is restricted to lower than 5% and 2C 3A +C4AF lower than 25%. The SRC can be used for structural concrete wherever OPC or PPC or Slag Cement are usable under normal conditions.
The use of SRC is particularly beneficial in such conditions where the concrete is exposed to the risk of deterioration due to sulphate attack, for example, in contact with soils and ground waters containing excessive amounts of sulphates as well as for concrete in sea water or exposed directly to sea coast.
The use of Sulphate Resisting Cement is recommended for following applications:
  • Foundations, piles
  • Basement and underground structures
  • Sewage and water treatment plants
  • Chemical factories
  • Suitable for underground works where Sulphate is present in the Soil and water.
Sulphate Resisting Cement is Not Suitable for:
  • Sulphate resisting cement is not suitable where there is danger of chloride attack. This will cause corrosion of rebar.
  • If both Chlorides and Sulphates are present, Ordinary Portland Cement with C3A between 5 & 8 should be used.
7) Applications of Low heat Portland cement
Low Heat Portland Cement is particularly suited for making concrete for dams and many other types of water retaining structures, bridge abutments, massive retaining walls, piers and slabs etc. In mass concreting, there is often considerable rise in temperature because of the heat produced as the cement sets and hardens. The shrinkage which occurs on subsequent cooling sets up tensile stresses in the concrete may result in cracking. The use of low heat cement is advantageous since it evolves less heat than OPC. This cement is not available in the market on regular basis and has to be obtained on specific orders.
8) Applications of Rapid hardening cement
The Rapid Hardening Cement is used for repair and rehabilitation works and where speed of construction and early completion is required due to limitations of time, space or other reasons. The cement is to be used in cold weather concreting i.e. temperature < 5oC. Rapid hardening cement is basically OPC but its fineness is 3250 cm2/g against 2250 cm2/g in case of OPC. The compressive strength after 1 day is 16 N/mm2 and that of 3 days 27 N/mm2.
These days higher grade OPC are available in the country to meet these requirements and therefore, this cement is not being manufactured and marketed on regular basis. The characteristics of this cement can be effectively met by only good quality 53 grades OPC.
9) Applications of Hydrophobic Portland cement
Hydrophobic Portland cement is manufactured on special requirement for high rainfall areas to improve the shelf life of the cement. The cement particles are given a chemical coating during manufacturing which provides water repelling property and the cement is not affected due to high humidity and can be stored for a longer period. This has to be obtained on special order from the cement manufactures.
Regards
Harshal S Khode
Sonukhode1351980@gmail.com
Dear,
1) ACC
2) JSW
3) RELIANCE
4) ACC
5) ULTRATECH
6) CORROMANDAL
7) BIRLA A1 PLUS
8) ZUARI
9) WONDER
10) PENNA
11) ORIENT
12) NIRMA
13) KESORAM
14) JINDAL
15) HEBBAL
16) CHETTINAD
17) JAYPEE
18) HATHI
19) AMBUJA
20) LAFARGE
21) J.K CEMENT
  • Marine structures
Regards
Harshal S Khode
Thank you for such a detailed explanation.
If you're considering switching from Ultratech Cement to another brand like Coromandel, it's totally fine as long as you keep a few factors in mind. Ultratech is a reliable choice for OPC and PPC, but other well-known brands like Ambuja, ACC, and Shree Cement offer excellent alternatives. When choosing a cement brand, it’s important to consider the quality and strength required for your specific project, the type of cement (like OPC, PPC, or PSC), and price differences. Reputation matters too—brands like Ambuja are known for consistent quality and sustainability. Coromandel Cement, for example, is a strong contender for both OPC and PPC use, offering good durability. Always compare prices from local dealers, check for availability, and, if possible, test the quality before making a final decision.
