Dear Students, Hope your Preparation is going Great for SSC JE.
As SSC announced SSC JE 2017-2018 test From 22nd Jan. To 25 January So now we have only 20 Days Left for Test.
Let us now look at the SSC JE Civil Preparation Strategy.
Knowing the SSC Civil Syllabus Thoroughly
From Last Year (2016) Papers all 8 Sets, we analyse weightage of Subjects from which questions are asked :
SOM > BMC > R.C.C. > C.T. > FM > Survey > Steel > Estimation > Geotech > Environment Engg. > Highway > Irrigation.
SOM ------------------------------131
BMC -----------------------------114
R.C.C.----------------------------101
C.T ------------------------------86
FM ------------------------------80
Surveying -----------------------76
Steel -----------------------------59
Estimation-----------------------53
Geotech -------------------------35
Env.Engg------------------------27
Highway-------------------------20
Irrigation------------------------18
Total ---------------------------------800 In 8 Shifts { Each Have 100 Technical Questions }
This will help you in Preparation.
Focus on the Theoretical Concepts
Mostly 70% – 80% of the paper is based on the theoretical concept.
Hence, you need to focus more on knowing the basic theoretical concept .
you can only answer them if your basics are strong. Questions will be related to RCC Steel & IS Codal Provisions will cover a great portion of the paper. The numerical will mainly be asked from Surveying, RCC , Estimation , SOM , which are mostly Easy.
Daily Revision With Your Notes
Going through your Handwritten Notes will solve your doubts easily and Most Helpful in Preparation of Exam.
As you made them after studying full content and made them fully short for Revision.
Practice Previous Years Papers
Practice Previous years papers at least Two times Before Test and Focus on Reasoning as well as General Awareness section.
Time Management
As you know There is 200 Questions and you have to attempt in 120 Minutes. So Practice Mock Tests as well as Online Tests to boost your speed.
If you Need any help regarding SSC JE Then you can ask us By Comments Below.
Good Luck !
Civil4M Team.
Time Management
Good Luck !
Civil4M Team.
