Guys anybody can recommend fire proofing material to be applied on concrete member which is wrapped with carbon fiber sheet.
Could you recommend me suitable fire proofing material which can be applied on the surface of carbon fiber sheet and concrete?
And That proofing material should be endured at least 1.5 hour against fire.
Dear Friend,
As I can understand that you will need a FIRE PROOF PAINT to be applied onto the CARBON FIBRE SHEET/CONCRETE. Suggest you go for a fire proof paint ( also known as INTUMESCENT PAINTS ) which can resist fire for about 2.00 hours and more.
Noble Paints offers ‘
Fyretard’ fire-retardant paint and ‘
FyrePruffe’ intumescent coating – two immensely effective coatings that provide the ultimate in fire protection.
Noble Paints Pvt. Ltd.,Noble Tower, First Floor,G.K. Marg, Lower Parel,Mumbai-400 013.Tel : (022) 249742 86 / 87, E-mail: noblecare@noblepaints.com.
Asian Paints offers intumescent passive fire protection coatings for protection from all types of hydrocarbon and cellulosic fires.The
Pittchar XP range for hydrocarbon fires, The
Steelguard series for cellulosic fire protection.
fire retardant paint, fire retardant paint for steel structure, fire retardant paint for steel surface, fire retardant paint for wood, fire retardant paint for timber, fire retardant paint for ply board, manufacturer of fire coating products, Ameetuff Technical Paints Industries, manufacturer of fire proof paints, fire retardant paints, fire coating products, fire retardant doors, epoxy paints in india, supplier of insulating varnish, anti bacterial paints maanufacturer, heat resistant coating in india, fire proof paints for wood, fire retardant paints in india, fire stop barrier see this link for more details on fire resistant paints etc.
Heat Resistant and Intumescent Coatings see this link for more details on fire resistant paints etc.
Vermiculite, Intumescent Paint, Steel Structure fireproofing India see this link for more details on fire resistant paints etc.
In building construction we provide fire proofing at following places:
Electric duct where the cutouts are sealed using VERMICULITE material which are offered from well known brands like HILTI, FISTCHER, PROTECTA, ETC to name a few, this material is mixed as per manufacturers spec and laid into the cutout so as to seal them incase of fire in electric ducts due to short- circuits etc.
Then STAIRCASE DOOR SHUTTERS are coated with FIRE RESISTANT paints which can withstand fire for about 2.00 hours, here even the door shutters are also used of FIREPROOF MATERIALS, which could be flush doors with ASBESTOS SHEETS on both outer faces of the shutters, could be metal doors etc, basic idea is to have a fire resistance of 2 hours plus so that there is ample time to vacate the premises.
Concrete and masonry are itself fire resistant and can withstand fires so making use of these materials also as per their suitability and uses.
::: EMIRATES TECHNOTRADE L.L.C ::: see this site, here you will find all the various locations where we can provide fire resistance.....
Please go through and select the material most suitable for your use.......Cheers
