How to Calculate Cut length of Haunch Bar of UGWT
75mm is a thickness of waterproofing, mostly its a shahabad type box water proofing.View attachment 1580
There are two triangle's. Read the image care fully.. 75 mm is not the cover .to the bar it is just extra plaster given on outer face of the tank. If it were to be the cover to the reinforcement then RCC consultant would have shown that same inside of the tank also .. mind it. . Slant length I have calculated. But for complete length u need to add 2x LD AS PER UR RCC CONSULTANT general drwng.. I hope this helps...
Here is the calculation
Haunch size150*150ka h,wall thickness 300,raft thickness 300Give cut length of haunch length
Sir hunch 450*150 and raft cover 75mmYour hunch is in 45 degree and have height and width of 230mm.
Extend it to wall and raft and form a triangle
In wall area it will add up height of 250mm
so the height of triangle will be
250mm (wall) + 230mm(hunch) + 380mm(raft) - cover from both side
same way you will get base length of the triangle and it will be same.
Angle is 45 degree, you can calculate the length of bar by using any trigonometric equation. it will give you the length of bar which is in slope.
Rest is the LD / Anchorage Length as per dia and drawing details.
You can do calculation of hunch bar length on your own, base on above given examples by many.Sir hunch 450*150 and raft cover 75mm
Or hunch 40mm
This is the tricky question , and its answer is 0 .Bro can u help me.. please solve this problem
