There is a building which has no space left either in front or rear and it has space in the two sides of building wall and one can do 4 cement ring wells along the wall but what if it cause any damage to the wall and you can find more info about the problem in the below post
diy.stackexchange.com
How to drain grey water in clay ground in safe and secured manner
I have a building which sits on top of clay ground so I couldn't soak away the grey water. I explored solutions like leechfield,soakaway,cement ring well but all fails in clay ground. I'd like some
