How to properly clean an 18k gold and diamond pendant?
mklop
To properly clean an 18k gold and diamond pendant, start by preparing a gentle cleaning solution using lukewarm water and a few drops of mild dish soap. Soak the pendant in the solution for 10–15 minutes to loosen dirt and oils. Use a soft-bristled toothbrush to gently brush around the diamond and gold surfaces, paying special attention to crevices where grime can build up. After brushing, rinse thoroughly with clean lukewarm water and pat dry with a soft, lint-free cloth.
Tips for best results:
  • Avoid harsh chemicals like bleach or ammonia, as they can damage the gold finish.
  • Do not use abrasive cloths or brushes that can scratch the metal.
  • For regular care, wipe your pendant with a soft cloth after each wear to maintain its shine.
If your pendant has intricate settings or stubborn buildup, consider having it professionally cleaned by experts.
Explore elegant, high-quality 18k gold & diamond pendants and care tips at Kesav Diamond: Diamond Pendant for Women – Buy Online in India | KESAV Diamonds
