Internal Plumbing Pipes and Fittings cost comparison
When it comes to plumbing along with the life of pipes and fittings, comparing the cost is also important in order to make a best buy out of all available plumbing pipes and fittings in market.
When a project is started, the comparison sheet is prepared by taking quotes from various Brands who manufacture the plumbing pipes and fittings.
I have attached below a a sheet which shows cost comparison for Plumbing pipes and fittings and includes following;
Solvent Weld Pipe & Fittings and Multilayer pipe & Composite Fittings.
Solvent Weld Pipe & Fittings and PPR pipe & Fittings.
Solvent Weld Pipe & Fittings and CPVC pipe & CPVC Fittings.
PPR pipe & PPR Fittings.
Multilayer Composite Pipe & Composite Fittings.
Tata - C class Pipe & "R" Brand Fittings (G.I. Pipe & G.I. Fittings).
Copper Pipe & Fittings.
The above 8 options gives clear indication for choosing the best plumbing piping system for your Project, use this sheet as a reference for creating your own comparison sheet at current rates.
  • Internal Toilet Pipe Matirial Cost Comparision .xlsx
