Land Slide at Wadala Dosti Acres Mumbai
rameshchandrapatel
Active Member
The causes of landslides are usually related to instabilities in slopes. It is usually possible to identify one or more landslide causes and one landslide trigger. ... Causes may be considered to be factors that made the slope vulnerable to failure, that predispose the slope to becoming unstable.
Slope instability can be manifested as landslides—including mudflows ("mudslides") and rockfalls—or by more subtle processes such as soil creep. Slope instability is a complex phenomenon that can occur at many scales and for many reasons. Landslides can be fast or slow, wet or dry, small or large, shallow or deep, old or recent. Examples of triggering mechanisms include earthquakes, grading, poor surface drainage, erosion, rainstorms, landscape irrigation, or broken utility lines. Fast-moving mudflows and debris flows are of particular concern in wildfire burn areas and in areas that have previously experienced landslide activity.
Buildings and infrastructure located on or in the path of a landslide can be seriously damaged or destroyed. Slope movements do not need to be large to be destructive—even slope creep or small, early-stage landslide movements can cause substantial structural damage to critical facilities such as dams, resulting in major economic damage and loss of life. Conversely, earth movements initially suspected to be caused by landslides might instead be the result of other processes such as fill settlement, shrink-swell action of expansive soil, or hydrocompaction of collapsible soil.
Reactions: sivaprasad7
Jayant Joshi
Senior Member
For such area proper rain water drainage must be constructed, in any case no rain water should flow to near by excavated area.
Because water flow will always drag soil and results in such land slide.
One should refrain to start such excavation work during rainy season, particularly in Mumbai where we receive heavy rain.
