low cost precast house within your budget
hi friends
after a long tedious hard work and doing lot of trail and error method i have constructed a rcc house of 440 sq.ft of built up area with in the cost of 3.5 lacks rupess.
the detailed project specifications are as follows:-
1. structure " totally r.c.c. with m40 grade concrete of vertical walls and precast slab of m30
2. area: carpet 320 sft. built up 440 sft
3. tiles: 2'x2'vitrified tiles.
4. dado : porcelona tiles
5. internal color wash : OBD
6. external color : apex
7. electrical point : living room 2 light points, 1 fan point. bed room i fan and light point. kitchen 1 light ;point,i 16 amp socket for fridge and 1 amp socket for grinder
8. w.c.: 1 light point
the above cost at factory. in case if some one need to be constructed outer bombay transport shall be extra. GST EXTRA
DURATION : 30 DAYS
FOR ANY ENQUIRY PL CONTACT : srini.reng55@gmail.com and dynamicprecast_786@rediffmail.com
Images
MAR
Founder Member
hi friends
after a long tidious hard work and doing lot of trail and error method i have constructed a rcc house of 440 sq.ft of built up area with in the cost of 3.5 lacks rupess.
the detailed project specificagtion as follows:-
3. tilesw: 2'x2'vitrified tiles.
5. internal colour waah : OBD
6. external colour : apex
7. elewctrical point : li nving room 2light points, 1 fan point. bed room i fan and light point. kitchen 1 light ;point,i 16 amp socket for fridge and 1 amp socket for grinder
8.w.c.: 1 light point
the above cost at factpory. in case if some one need to be constructed outer bombay transport shall be extra. GST EXTRA
DURATION : 30 DAYS
FOR IMAGE REFER THE ATTACHEMENTS
Amazing & lovely construction. India needs such type of constructions
It will be even more better if you can share the Architectural Plan & Costing details of the same. Even the PDF file also works for this. It may be helpful
Reactions: tryalphaa
As the patent rights not obtained providing the details you have asked for not possible to provide
