What is any part of the computer that you can physically touch?
Hardware
Which genertion of computer is still under development?
Fifth
What is the most common storage device for the personal computer?
Floppy disk
Which key is used in combination with another key to perform a specific task?
Control
What is the pattern of printed lines on most products?
Barcodes
To make the number pad act as a directional arrow, we press which key?
Shift
Which devices that let the computer communicate with you?
Input
What is the most frequently used piece of hardware for inputting data?
Hardware
What is the place where the computer stores programs and data?
Storage unit
What is the process of dividing the disk into tracks and sectors?
Formatting
What is the space in your computer that loads’ and works with data?
RAM memory
What is the storage which stores or retains data after power off?
Non-volatile storage
What will be Typical acronym of reuseable optical storage?
CD-Rom
What contains specific rules and words that express the logical steps of an algorithm?
Syntax
What is the pictorial representation of a program or algorithm?
Flowchart
What is the smallest unit of information a computer can understand and process?
Bit
Which is a program that make easy to use a computer?
Utility
What converts and executes one statement at a time?
Interpreter
What includes the programs or instructions?
Software
Who designs. writes tests and maintains computer programs?
Operator
Who writes and fests computer program?
Programmer
What term used to define all input and output devices in a computer system?
Hardware
What is a word in a web page that, when clicked, opens another document?
Hyperlink
What refers to a small, single-site network?
LAN
What does consist of one or more Web pages located on a Web server?
Aweb site
What does allow voice conversations to travel over the Internet?
Internet telephony
Which software that allows users to surf the internet?
Browser
What does allow you to access objects and start programs?
Start menu
What contains commands that can be selected?
What of software contains lists of commands and option?
Menu bar
Data that is copied from an application, where is stored?
In the clipboard
Which menu type is also called a drop down menu?
Pull-down
What includes the file name and possibly a directory of folder?
File directory
What is the name a user assigns to a document called?
Filename
What is in text that you want printed at the bottom of the page?
Footer
What is a document means to make changes to its existing content?
Edit
A microprocessor is the brain of the computer and is also called by which name?
Microchip
Which type of computer could be found in a digital watch?
Embedded computer
What takes on different shapes depending on the task you are performing?
Mouse pointer
Soft copy is an intangible output, so then what is a hard copy?
The printed output
One puts information into the computer by pressing which key?
Enter
Letters, numbers, and symbols found on a keyboard are, called by which name?
Keys
What is the data and instruction entered in the memory of a computer?
Input
What usually appears in the shape of an arrow?
The mouse Pointer
What is the primary device that a computer uses to store information?
Hard drive
Which is uses laser technology to store large amount of information?
CD-ROM
What part of the computer provides only temporary storage of files?
RAM memory
Which is a removable magnetic disc that holds information?
Floppy disk
Formatting
What is the box that houses the most important parts of a computer system?
System unit
The operating system called UNIX is typically used for which computers?
Web computers
What is an error in a program which causes wrong result?
Bug
What is a program that makes the computer easier to use?
Utility
What is the process of preparing a floppy diskette for use?
Formatting
Which is the part of a computer that one can touch and feel?
Hardware
What are the peripheral devices such as printers and monitors considered?
Hardware
Which device that connects to a network without the use of cables?
Wireless
What is a popular way to learn about computers without ever going to a classroom?
E-learning
To view information on the web, what must you must have?
Web browser
Which devices are used to transmit data over telecommunications lines?
Modems
Which software program used to view Web pages?
Browser
Which Output is made up of pictures, sounds, and video?
Multimedia
An email account includes a storage area, what is often called?
Mailbox
Something which has easily-understood instructions, what is said to be?
Analog data
What are lists of commands that appear on the screen?
Menus
Windows 95, Windows 98, and Windows NT are known as what?
Operating systems
What is the term used to describe the window that is currently being used?
Active Window
For creating a document, you use which command at file menu?
New
What is to add or put into your document such as a picture or text use?
Insert
Which elements of a word document can be displayed in colour?
All elements
What is a collection of information saved as a unit?
File
Numbers and formulae entered in a cell, what are called?
Numeric entries
What is a collection of related information sorted and dealt with as a unit?
File
A command that saves what you are working on into the hard drive,?
Save
Which mouse technique is used for access in properties of any object?
Right clicking
Which Powerful keys that let you exit a program when pushed?
Escape key
Which devices you use such as a keyboard or mouse, to input information?
Input device
Which device can understand difference between data and programs?
Microprocessor
What is the mean of data gathering in computer?
They allow to use data Store
What is the set of instructions which tells a computer what to do?
Program
The operating system is the most common type of which software?
System
Which peripheral device displays information to a user?
Monitor
Which manual tells you how to use a software program?
User
What is the most important or powerful computer in a typical network?
Network server
What makes it possible for shoppers to make purchases using their computers?
E-Commerce
By which name also called the web, contains billions of documents?
World Wide Web
Generally, you access the recycle bin through an icon, where is this located?
On the desktop
What is a blinking indicator that shows you where your next action will happen?
Cursor
Which type of file is created by word processing program?
Document file
In a spreadsheet program, which contains related worksheets and documents?
Workbook
Which application is commonly used to prepare a presentation/ slide show?
Power Point
In which group do we work at the time of text formatting in Word?
Table, paragraph and indexes
Which computer refers to the fastest, biggest and most expensive computer?
Super computer
Which device is used as the standard pointing device in a Graphical User Environment?
Mouse
Which key moves the cursor one space to the right or puts spaces in between words?
Space bar
The speakers attached to your computer used for which purpose?
Handling sound and music
What is the box that contains the central electronic components of the computer?
System unit
What happens when the computer is turned on and the operating system is loading?
Booting
The process of writing out computer instructions is knowns as which name?
Compiling
What is the ability of an OS to run more than one application at a time?
Multitasking
Hardware
Fifth
Floppy disk
Control
Barcodes
Shift
Input
Hardware
Storage unit
Formatting
RAM memory
CD-Rom
Syntax
Flowchart
Bit
Utility
Interpreter
Software
Operator
Programmer
Hardware
Hyperlink
LAN
Aweb site
Internet telephony
Browser
Start menu
Menu bar
In the clipboard
Pull-down
File directory
Filename
Footer
Edit
Microchip
Embedded computer
Mouse pointer
The printed output
Enter
Keys
Input
The mouse Pointer
Hard drive
CD-ROM
RAM memory
Floppy disk
Formatting
System unit
Web computers
Bug
Utility
Formatting
Hardware
Hardware
Wireless
E-learning
Web browser
Modems
Browser
Multimedia
Mailbox
Analog data
Menus
Operating systems
Active Window
New
Insert
All elements
File
Numeric entries
File
Save
Right clicking
Escape key
Input device
Microprocessor
Program
System
Monitor
User
Network server
E-Commerce
World Wide Web
On the desktop
Cursor
Document file
Workbook
Power Point
Super computer
Mouse
Space bar
System unit
Booting
Compiling
Multitasking
