minimum spacing of ties in Columns and it's condition?
First divide the column length into three parts as
Let L be the total length of column
1)L/4 From the bottom
2)L/4 from the top
3) Remaining part(Central portion)
#Give the spacing of ties in bottom and top L/4 portion as minimum
& Reason :Stress on the column is maximum at this portion due to load transfer,in order to counter that ties are provided with minimal spacing.
#Give the spacing of ties in centre portion as maximum
& Reason:Stress is very less in centre portion and hence ties are provided with maximum spacing.
Example:
Suppose take a column of length 10m, stirrup (Ties)of Dia 8mm
#8mm @ 100mm c/c @ 2.5 m from both ends
#8mm @200mm c/c @ 5m in central part
Reactions: Venkatshanthi
Venkatshanthi
Senior Member
2)L/4 from the top
Example:
Any code book reference this answer..?
amd007
Elite Member
There can be no GENERALISATION OF SPACING OF TIES in any structural member, it all depends on the STRUCTURAL DESIGNERS and hence can keep on changing based on the design parameters set out by the Structural Designer.
