Polypropylene Random Co polymer- PPR-pipes fixing methodology
PPR pipe means Pipe made of Polypropylene Random Co polymer (Polypropylene Random Co polymer type 3). ... PPR pipes are designed as the most hygienic system for the transportation of portable water. PPR pipe have a long life time over 50 years even in the cold and high temperature and stress pressure situation.
PPR - Presently PP-R pipes & fittings are most reliable in plumbing and water supply plants, due to their chemical features and fusion welding, which ensures the plumbing to have a perfect seal tight system. It can be used both as a cold water pipe or a hot water pipe.
find enclosed herewith the method statement for fixing the ppr pipes.
  • PPR Pipes method statement.R.S.pdf
Reactions: ceLebi
