Presentation on Internal Plastering Works
Plastering helps provide better sound and thermal insulation and fire resistance. A good plasterer should have a sound knowledge of materials to use and their characteristics. A plasterer should identify the correct materials and their suitability for any given situation. A good plasterer should be able to put right any problems with their work and that of others.
I have attached below, a presentation on internal plastering work which includes following in details;
Background surface for plaster
the rate of suction of the background before applying plaster.
High Suction Background
Medium Suction Background
Low Suction Background
Expanded metal lathing
Composite backgrounds
Preparation for plastering works
Methods of work
Broad screeds
Dot and screed
Applying a key
Finishing
Trowel and float
Beads for plastering
Float ( angle ) bead
Stop bead
Feature beads
Movement beads
Materials for plastering
Thistle hardwall
Thistle toughcaot
Carlite browning
Dri coat
Limelite renovating
Board finish
Multi finish
Dura grade
High impact finish
Presentation is attached below.
Password to open presentation is civil4m
Methods of work
Broad screeds
Dot and screed
Applying a key
Finishing
Trowel and float
Stop bead
Feature beads
Movement beads
Thistle hardwall
Thistle toughcaot
Carlite browning
Dri coat
Limelite renovating
Board finish
Multi finish
Dura grade
High impact finish
