Presentation on MB Measurement book to be prepared in Government Contract Works
Payments for all work done otherwise than by departmental labour and for all supplies are made on departmental labour and for all supplies are made on the basis of measurements recorded in Measurement the basis of measurements recorded in Measurement Books.
It is an important collective record of It is an important collective record of Measurements. Measurements recorded for the works executed and materials supplied.
The measurement books should be considered as very important record. All the books belonging to a division should be numbered serially and a register of them should be maintained in the divisional office showing
the serial number of each book,
the name and designation of the person to whom issued,
the date of issue and
the date of its return.
A similar register should also be maintained in the sub- -divisional office.
Books no longer in use should be withdrawn promptly even though not completely written up.
Presentation on MB Measurement book includes following topics in it;
How to write in measurement book
powers to be exercised in recording measurements (Open Line)
powers to be exercised in recording measurements (Construction)
Detailed measurements
Standard type Drawings
Material Consumption
Method of Calculation of Quantities for concrete work
Quantities of Ingredients of Stone Masonry in Cement Mortar per Cubic Meter
Quantities of Ingredients of Cement Plastering over Brick Work 1.25 cm Thick per Square Meter.
Quantities of Ingredients of Cement pointing over Brick work per Square Meter.
Estimated Quantities of Materials Required Per CUM of compacted Mortar and concrete
Reinforcement - Areas and Weight of Rods
Presentation is attached below
