presentation on plumbing and sanitation
Elite Member
Sep 21, 2017
265
370
India
#1
Plumbing, system of pipes and fixtures installed in a building for the distribution and use of potable (drinkable) water and the removal of waterborne wastes. It is usually distinguished from water and sewage systems that serve a group of buildings or a city.
One of the problems of every civilization in which the population has been centralized in cities and towns has been the development of adequate plumbing systems. In certain parts of Europe the complex aqueducts built by the Romans to supply their cities with potable water can still be seen. However, the early systems built for the disposal of human wastes were less elaborate. Human wastes were often transported from the cities in carts or buckets or else discharged into an open, water-filled system of ditches that led from the city to a lake or stream.
he
You do not have permission to view link Log in or register now.
plumbing fixture embraces not only showers, bathtubs, lavatory basins, and toilets but also such devices as washing machines, garbage-disposal units, hot-water heaters, dishwashers, and drinking fountains.
The water-carrying pipes and other materials used in a plumbing system must be strong, noncorrosive, and durable enough to equal or exceed the expected life of the building in which they are installed. Toilets, urinals, and lavatories usually are made of stable porcelain or vitreous china, although they sometimes are made of glazedcast iron, steel or stainless steeln. Ordinary water pipes usually are made of steel, copper, brass, plastic, or other nontoxic material; and the most common materials for sewage pipes are cast iron, steel, copper, and asbestos cement.
find enclosed herewith a detailed presentation on the above subject
