Topics for Project Work on structural engineering
Here are few topics which you can choose for seminar presentations or project work in structural engineering:
- Evaluation of marine salts properties near the bridge structures
- A relative research on durability of concrete tunnels carried out in AP irrigation projects
- Multistory structure which are already fabricated, contact to engineering seismicity
- Shape optimization of Reinforced underground tunnels
- Characteristics of Fiber Cement Boards for building partitions
- Properties of RC Structures when led blasting
- The usage of green materials in the manufacturing of buildings
- Finite element model for dual composite beam
- A fresh composite element for FRP Reinforced Concrete Slab
- Effect of shear lag on anchor bolt tension in a base plate
- Pushover analysis – cyclic loading, deterioration effect in RC Moment Frames in pushover analysis
- Rehabilitation –Assessment of the drift distribution
- Assessment of big dynamic structure in environmental industry
- Speculative study on High frequency fatigue properties of concrete
- Seismic evaluation of interlocking blocks in walls
- Plastic elastic bending, weight carrying capability of steel members
- FE Evaluation of sideways buckling of a plate rounded in property
- Indoor technology and promotion of green energy for smart buildings
- Constructing environmental assessment techniques
- Mathematical study on amplification of composite bridges
- Amplification effect for RC member under negative bending
- Consequences of negative Poisson’s ratio on bending of RC member
- Macroeconomic cause inside the life span of bridges
- Long term deflections of long span bridges
- Structural harm exposure in plates using wavelet theories (transforms)
