Rate Analysis of Bitumen works done in Road and Highways
Chetan Yadav
Rate analysis of all bitumen works done in Roads and Highways are attached in this thread.
Following items rate analysis available in this attached sheet;
1. Prime Coat
2. Tack Coat
3. DBM
4. BC
5. CRMB 55
6. Mastic Asphalt 40mm
7. Mastic Asphalt 25mm
Snapshot of summary sheet
Download the rate analysis of bitumen works done in Roads and Highways from below attachment
  • Rate analysis for Bitumen Works.xls
There has been a lot of recent research regarding the benefits of using tack coats between hot mix asphalt lifts and how it helps extend the lifespan of HMA overlays. We used to take these applications for granted, but that is no longer case anymore.
This paving season, our jurisdiction is actually introducing a new specification requiring longitudinal pavement joints to be sealed prior to subsequent lifts being installed (HERE'S A LINK): http://www.idot.illinois.gov/Assets...-Environment/BDE-Special-Provisions/80398.pdf
A couple of years ago, I wrote an article describing how prime coat application rates are measured & calculated that might also be of interest to those members involved in HMA paving (HERE'S THE LINK) Prime Coat Calculations for IDOT
