Sample rate analysis for Construction works
i have attached herewith rate analysis for following construction works;
Rate analysis of Brick Work
Rate analysis of Cavity Wall
Rate analysis of Plinth Protection
Rate analysis of Honeycombed wall
Rate analysis of Foundations
Rate analysis of Plinth Beam
Rate analysis of Columns
Rate analysis of Vertical DPC
Rate analysis of PCC
Rate analysis of Terrazzo Topping
Rate analysis of Plaster on Masonry Surface
Rate analysis of Plaster for ceramic tiles wall.
Rate analysis of Plaster for Terrazzo Skirting
Rate analysis of Leveling course for Terrazzo Flooring
Rate analysis of Terrazzo Tiles
Rate analysis of Big size Manhole
Rate analysis of small size manhole
Rate analysis of Ceramic tile flooring
You can download it from below attachment and modify its content as per your requirements.
  • Rate analysis of construction works.xls
