Special Type of Concrete - Cellular Lightweight Concrete (CLC)
Cellular light weight concrete is used in the production of Cellular blocks, as roof insulation material , for prefabricated panels as structural members for low cost construction.
Cellular concrete like conventional concrete ages well, increasing its strength by as much as 50 % between 28 days and 90 days after pouring. As long as cellular concrete draws humidity from the atmosphere it will keep on increasing its mechanical properties.
Cellular concrete is produced using “Neopor” foaming agent with Natural sand and cement with water.
“Neopor” cellular lightweight concrete can be cast in situ or it can be a pre-cast. It can be cast in bricks for masonry or walls using fly ash in the concrete. The concrete has to be prepared with foam manufactured by foam generating machine and mixed with concrete.
Raw material for the cellular concrete:
The ingredients in the concrete is foam like “Neopor” , Sand , Cement and water.
Type of plant required for making neopor foam :
Neopor Foam generator “BK-8” has to be imported from Germany which can produce approximately 8l/sec (28.8 m3/ hour) sufficient to produce 50-60 m3 of cellular concrete/hour with Noise reducing rotation air-compressor , self-priming side- channel pump, including foam-lance, electr. Control-box and timer, drive 380/400 V, 50 cycles electric motors.
Type of foaming agent
Neopor – 600 Foaming agent is required for the production of highly stable foam. 1 kg of foaming agent with 40 litres of water produces 540 litres of foam.
Neopor foaming agent is based on a protein – hydrolisation. It causes no chemical reaction but serves solely as wrapping materials for the air to be encapsuled in the concrete(mortar).
Some of the physical properties of cellular concrete:
1. Range of densities : 400 to 1800 kg/cum.
2. Compressive strength : 10 kg/cm2 to 250 kg/cm2.
3. Shrinkage behaviour : 0.215 mm/ m with a density of 1200 kg/cum and 0.145mm/m with higher densities.
4. Thermal conductivity : 0.082 to 0.555 (W/mK) and dense concrete – 2.1 (W/mK)
5. Fire rating : non combustible
6. Water absorption : approx. 5 % at a density of 1200 kg/cum no condensation closed cellular structure.
Recommended mix design for cellular concrete based on a mixing volume of 1 cum.
Density In Kg/Cum40080012001600
Material
Weight and Volume
Weight and Volume
Weight and Volume
Weight and Volume
Sand
420 Kg
160 Lit​
780 Kg
297 Lit​
1130 Kg
430 Lit​
Cement
300 Kg
97 Lit​
320 Kg
103 Lit​
360 Kg
116 Lit​
400 Kg
129 lit​
Water
110 Lit​
120 Lit​
140 Lit​
160 Lit​
Neopor Foaming agent
1.5 kg​
1.2 Kg​
0.9 Kg​
0.6 Kg​
Foam by Volume
800 Lit​
630 lit​
460 lit​
290 Lit​
Water In Foam
60 Lit​
46 Lit​
35 Lit​
21 Lit​
Wet Concrete
470 Kg
1007 Lit​
906 Kg
1013 Lit​
1315 Kg
1013 Lit​
1711 Kg
1009 Lit​
Sand grading : A minimum of 20 to 25 % fine sand ( less than 300 microns is) is recommended for better physical properties.
Cement : Cement used in the production of foam concrete is usually OPC. However blended cements can also be used but blended cement results in slower rate of strength gaining.
Fly ash to an extent of 25 % or more of the mix can also be used in production of cellular concrete blocks and prefabricated elements with density of 1000 kg/cum to 1200 kg/cum.
The mix proportions in such case will be :
Cement (Portland) = 190 kg
Content of air in concrete = 43% approx.
Fly ash = 309 kg
Content of fly ash in solid material : 33% Sand = 430 kg
Content of fly ash in oven dry material : 31% Water = 250 Liters
Wet density = 1179 kg/cum
Foam = 423 Liters
Oven dry density = 1000 kg/cum (approx)
DilipShah
Apprentice
Completely Non-toxic "GREEN"Material "Environmentally Friendly"
Eco Friendly Cellular Lightweight Concrete Blocks - KALMATRON® ADMIXTURES
We are seeking to develop our products' market in Indian, they are in search of Agency partners in the continent. We would like to work with you.
Kalmatron® Admixtures are not based on crystalline technology but on the complete Hydration of the cement gains increasing the yield of the cementitious gel per batch. Kalmatron® is also patented in the US and internationally.
Cellular Lightweight Concrete blocks (CLC) are a good GREEN substitute for traditional concrete hollow blocks for several reasons.
It is completely safe for the environment, as there is no CO2 emission and no harmful leaching.
Cellular Lightweight Concrete blocks (CLC) are a good GREEN precast concretelight wall panel By KALMATRON® KF-ASH.
There are No Foaming agent require.
Construction and Demolition (C&D) waste generated, recycled aggregates (RA) produced from C&D waste and their utilization in concrete and governmental initiatives towards recycling of C&D waste. Also with the liquid version of KF-Ash, called K100ASH, up to 70% IIW cement substitution is possible.
The lighter concrete, the costly it per square foot of the wall. Light-weight concrete is the most developed in the modern wall building industry. Dominating volume of big pores and enough strength make light-weight concrete widely used in southern countries. These walls are light and have good thermoresistance, but still need to be water protected and maintainance is expensive to keep required durability.
In both cases, the principle of air-heat resistance is used. As shown below, the best results for thermoresistance, waterproofing and durability could be achieved by a combination of heavy weight concrete durability with the high thermoresistance of light weight concrete. In developing ºBLOCK another modification has been designed for building of underground/ underwater walls capable of protecting enclosed accommodations by impermeable and thermoresistant structure.
Lightweight Concrete blocks KF-ASH provides maximum of cementitious value to concrete mix and prevents leaching of unstable phases from IIW by encapsulation of insoluble impurities. It increases the field of IIW utilization for chemically, biologically or organically contaminated raw materials.
The lighter concrete block, the costly wall: BLOCK ECONOMY :
http://blockdegree.homestead.com/BLOCK-ECONOMY.html?_=1373858784207
Provides cement reduction by up to 20%. It is a water reducer and plasticizer.
Application temperatures range from -4 degrees Fahrenheit up to 104 degrees Fahrenheit. No curing is needed, no other admixtures are necessary.
We do not use resin/Polymers + Fillers not at all. . No curing was needed under sun heat at 130°F.
Lightweight concrete has several advantages associated with their applications:
Lightweight
Fire resistant
Thermal insulation
Sound absorption and Acoustical Insulation
Environmental Friendly
Cost-efficient
Termite proof and resistant towards freezing issues.
http://www.blockdegree.com/
Visit us at
www.kalmatron.com
http://www.kalmatron.com/KALMATRON_LINE_CARD.pdf
World Cement - March 2018
https://www.worldhighways.com/categories/materials-production-supply/products/concrete-additive-boosts-performance/
http://www.kalmatron.com/files/files1/articles/kf-a_for_hpc.pdf
https://drive.google.com/file/d/0B0yFTfuHLutNUzFkdW9KeUhZTTRTazU4LTZycFk4WnBYbThR/view
http://kalmatroncn.homestead.com/KALMATRON--GALLEREA.html?_=1403368885385
https://drive.google.com/drive/u/0/folders/0B-ufT0sIXypsc1RTLXl0Mmw0eXM
https://kalmatroncorporation.tradeindia.com/construction-chemicals.html
