Tips to Identify Original Century Plywood from Dealers?
To ensure the quality, longevity and safety of your interior wood work, it is important to be able to identify original Century Plywood. To do this, you must look for the Century logo, grade marking and specifics about how the sheet was manufactured. These pieces of information will all be printed plainly on the surface of the sheet.
Risk of Buying Counterfeit Product:
Always buy from an authorised Century Plywood Dealer to decrease your chances of buying a counterfeit product. Always ask for a valid purchase invoice, warranty and a copy of the certificate, so that you can verify the product's authenticity. Original Century Plywood sheets have uniform thicknesses, smooth finishes and strong bond strength; if you tap the sheet, you should not hear a hollow sound. Be wary of prices for this product that are over the top or ridiculously low; counterfeit plywood is often sold at highly inflated prices. You can also compare with samples or consult an expert before you make your purchase if you are still unsure. If you select only original Century Plywood for your project, you will get the greatest level of strength and durability and that will give you an absolute peace of mind when you use it in your project.
