Types of floors constructed at Residential Building
Types of Floors:
1. Basement Floor
2. Podium Floor
3. Ground Floor
4. Mezzanine Floor
5. First Floor
6.Typical Floor
7. Terrace Floor
Basement Floor:
The floor which is constructed below ground level for store rooms or mechanical room or parking is known as Basement Floor.
Podium Floor:
The floor which is constructed either below ground level or above ground level, especially for car parking is called as Podium floor.
Ground Floor:
The floor which is constructed on ground level is called as Ground floor.
Mezzanine Floor:
The floor which is constructed between Ground and First Floor is called as Mezzanine floor. This type of floor is constructed for Services of building or storage of materials.in shops & offices, to provide facilities for the occupants who are living in High-rise buildings. For proper ventilation the ceiling height of floor is increased.
This floor is generally constructed where the ground floor height is around 4.5. to 5 meter and located at least 2.4. meter from the ground floor.level.
First Floor:
The floor which is constructed above ground floor or above mezzanine floor is called as first floor.
Typical Floor: Typical floor is nothing but repeated floor.
The plan which is design for Ground floor and want to have the same plan for other floors, then these floors are called as Typical floor-1 or typical floor 2, etc.
Terrace floor :
This floor also called as roof slab on which overhead tank lift machine room etc are located,this floor is the last slab of the building.
Types of Floors:
1. Basement Floor
2. Podium Floor
3. Ground Floor
4. Mezzanine Floor
5. First Floor
6.Typical Floor
7. Terrace Floor
Basement Floor:
Podium Floor:
Ground Floor:
Mezzanine Floor:
First Floor:
Terrace floor :
