Uses of plastic dialysis waste to produce durable concrete
Chetan Yadav
Dialysis patients could inadvertently improve sustainability in the construction industry, thanks to an innovative Deakin University recycling project that's turning hospital waste into longer-lasting concrete.
A team at Deakin's School of Engineering is behind the new project, which could ultimately save from the scrap heap the thousands of tonnes of plastic waste created in Australia each year through dialysis treatment.
Project leader Dr Riyadh Al-Ameri, a senior lecturer in structural engineering, said the project could solve two problems in one, with corrosion of steel bars used in concrete construction a major issue for the industry.
The project is a collaboration between Dr Al-Ameri and nephrologists Dr Katherine Barraclough from the Royal Melbourne Hospital and Professor John Agar from Barwon Health's University Hospital Geelong, and came about when the specialists approached Deakin to find a practical solution to their waste issue.
Dr Al-Ameri said his project team was hoping to use the shredded plastic waste to help better protect structural concrete from corrosion.
"Concrete can crack and damage the internal bond, which can then lead to water penetration and corrosion of the steel bars, critical for providing the strength and integrity of concrete structures.
"If we are able to facilitate production of new types of concrete that will offer better protection, give structures longer life and better performance, as well as help recycle plastic waste, that will be a great achievement."
Dr Barraclough said each dialysis treatment created between one and three kilograms of plastic waste, and with more than 12,000 Australians on dialysis, that added up to about 5,100 tonnes of plastic waste per year.
"Haemodialysis (the most common type of dialysis) involves making a circuit where blood is pumped from a patient's bloodstream through a machine then back to the patient. This removes toxins and excess water and is life sustaining for patients with kidney failure," she said.
"For safety reasons, both the tubes that carry the blood and the dialyser (the part of the machine that cleans the blood) are made of plastic designed for single use only. The result is large amounts of plastic waste generated from each dialysis treatment.
"Because the waste is potentially infectious, it must be either burnt or sterilised before being thrown away. This not only costs a lot of money, but also causes significant harm to the environment.
"With increasing numbers of people requiring dialysis in Australia and worldwide, we need to work out ways to reduce the costs of care delivery, as well as play our part in ensuring a healthy environment for future generations."
As part of some initial testing, Dr Al-Ameri's team added the shredded plastic waste to a concrete mix at concentrations of 0.5 per cent and 1 per cent by weight of concrete, with results showing this made a product that was more durable and significantly more water-proof.
"The 30 per cent decrease in water absorption we found is significant and would be expected to improve resistance of concrete to corrosion," Dr Al-Ameri said.
Now thanks to funding from industry partner Fresenius Medical Care - a global provider of dialysis products and services [ Dr Al-Ameri and his team hope to conduct more rigorous testing to see if this new concrete mix can stand up to harsh conditions.
"We will use our accelerated weather corrosion tanks in the concrete lab to simulate a marine environment," Dr Al-Ameri said.
"One month in the lab is equivalent to approximately one year outside, so we can observe the behaviour of the material quickly and efficiently.
"Wet and dry cycles can have a big impact on the durability of the concrete, and sea water has chloride, which is very harmful to both concrete and steel reinforcement.
"So we're looking for innovations that will help concrete construction of off shore rigs for oil and gas, observation towers, concrete buildings in coastal areas that are exposed to humidity, and marine structures such as retaining walls that are in contact with water."
Provided by: Deakin University
Reactions: Narendra
AS WELL AS TANNERY WASTE ALSO NOWADAYS COMING MORE ,SO WE HAVE TO UTILIZE IN OUR INDUSTRY AND ALSO I DID PROJECT ABOUT THIS TO MINIMIZE THE CEMENT CONTENT WITH TANERY ETP SLUDGE (IT CONTAIN SOME PROPERTIES WHICH CONTAINS IN CEMENT ,BECAUSE IN TANNERY THEY ARE USING LIME TO TREAT THE LEATHER IN THEIR PROCEEING) AND 10 % GAVES A BEST RESULT OF STRENGTH BUT 10 % ADDITION IT WILL NOT CHANGE THE COST OF PROJECT SO NEED TO ANALYSE MORE .IF WE ARE NOT PLAN IT WILL DUMP ON LAND AND IT WILL MAKE THE SOIL LAYER AS IMPERVIOUS .ITS AGAINST TO GROUND WATER RECHARGE .IF YOU WANT ANY DETAILS CONTACT ME AS I KNOW I WILL SHARE ABOUT TANNERY SLUDGE
