What is biaxial, uniaxial load..???
Axial load is the compressive load on the column
Uniaxial load results from a bending moment applied to the column around one axis only
Biaxial load results from bending moments applied to the column around both axes
BTW the bending moments may be transferred from attached beams or caused by the axial load being applied eccentrically to one axis or both axes rather than through the center of the column.
Thank you sir
