What is concrete vibrator and why is it so important to vibrate concrete after placing?
amd007
Elite Member
The vibrator is a mechanical device to consolidate or compact the concrete. A vibrator consolidates concrete in a two-part process. The first waves liquify the concrete so it flows better and the continuing waves knock out air bubbles
Right after it’s placed, concrete contains as much as 20% entrapped air, The amount varies with mix type and slump, form size and shape, the amount of reinforcing steel, and the concrete placement method.
At constant water-cement ratio, each percent of air decreases compressive strength by about 3% to 5%.
Consolidating the concrete, usually by vibration, increases concrete strength by driving out entrapped air. It also improves bond strength and decreases concrete permeability.
The problems associated with under vibration include:
  1. Honeycombing
  2. Excessive entrapped air
  3. cold joints
  4. subsidence cracking
The problems associated with over vibration include:
  1. segregation
  2. form deflection
  3. form damage or failure
