What is the difference between capping beams and ground beams for piles?
Answer: Capping beams for piles aim at transferring loads from closely spaced columns or walls into a row of piles. On the other hand, ground beams are beams provided between adjacent pile caps and they perform as compression struts or ties in an attempt to prevent lateral displacement or buckling of piles under uneven distribution of loads on pile caps. Both of them have to be specially designed to cater for differential settlement of piles. Capping beam performs the same
functions as pile caps. However, ground beams are structural elements to connect adjacent pile caps to improve the stability of foundation.
