What is the function of packing materials in the joint of concrete pipes in pipe jacking
Chetan Yadav
What is the function of packing materials in the joint of concrete pipes in pipe jacking?
Answer: Packing materials are about 10 mm to 20 mm thick and are normally made of plywood, fibreboard or other materials. In case packing materials are absent in pipe joints for pipe jacking, then any deflection in the joints reduces the contact area of the concrete and it leads to spalling of joints due to high stresses induced. With the insertion of packing material inside the pipe joints, the allowable deflection without damaging the joint during the pipe jacking process can be increased.
