Why is my YouTube TV location wrong?
Common reasons your YouTube TV location is wrong​
Several factors can cause YouTube TV to show the wrong location. Let’s look at the most common ones.
1. You’re using a VPN or proxy​
If you use a VPN, your internet traffic may appear to come from a different city, state, or even country. This can confuse YouTube TV and cause it to assign the wrong location to your account.
2. You recently moved​
If you’ve moved to a new home, YouTube TV may still be using your old location. You’ll need to update your home area and current playback area to reflect your new address.
3. Device location settings are turned off​
Some devices require location services to be enabled for apps to detect your position accurately. If these settings are disabled, YouTube TV may guess your location incorrectly.
4. Account home area mismatch​
YouTube TV uses both a “home area” and a “current playback area.” If these don’t match, you might see a warning or experience limited access to local channels.
5. IP address inaccuracies​
Sometimes your internet service provider assigns an IP address that is registered in a nearby city or region. This can result in YouTube TV showing local channels for the wrong area.
These issues are the main reasons users search for answers to Why is my YouTube TV location wrong?
