Spacer bars are basically provided to create sufficient gap , between more than one layers of longitudinal rebars if combinedly designed to be placed closely in either tension zone or in compressor zones , for the coarse aggregates of the concrete going to be placed. The size of the spacer hence , depends primarily on the maximum size of the coarse aggregates + some extra for better workability ( minimum 5mm as per standards).
