Will going from a 3-tap to 6-tap increase water pressure
Chetan Yadav
Will going from a 3-tap to 6-tap increase water pressure?
Answer: No, the pressure will be the same; you will get more volume only if your pumps can handle the GPM, to increase pressure you may need a booster pump or a single pump that is rated for your needs.
