A Complete Guide to Multiphase Flow Simulation Using ANSYS Fluent CFD
In industrial processes, multiphase flow is not only prevalent—it is necessary. From pipelines and evaporators to chemical reactors and crystallizers, multiphase systems are central to many unit processes across many industries. Among these, the oil and gas industry is one of its biggest players of these systems. The industry is not only a leading provider of global energy supply but also a principal supplier of raw materials to many chemical industries, particularly the petrochemical industry.
AD_4nXf31oV6COSGK5_zdoOVp-ZfA_yR7Ai-DMaKFIPcGIKPEkz11bIWnBT4xFS-CFiHovla24HutnJTJ3MDgPzBxYdIiFdOoGwa2KYoN4QFugq8lYdtVZ5SrVEB6cTRMlr89rln0dQO
With its far-reaching reach, every advancement in the oil and gas sector can lead to huge operational advantages and vast economic benefits. For this reason, process efficiency and accuracy are of the utmost priority.
Simulation: The Key to Process Optimisation​
In the highly technologically developed world of today, the initial logical step toward process improvement is through simulation. Numerical simulation of a process provides a valuable tool for gaining insight into system behaviour, investigating the effect of different parameters, and testing different operating conditions without entering a laboratory. These capabilities are now standard in many online training modules and practical learning formats that focus on computational fluid dynamics courses tailored for industrial use.
Simulation is a cost-efficient and time-saving option compared to experimental testing, particularly for complicated systems. Experimental setups for analysing multiphase flow are not just costly but also take time and are difficult to replicate under different circumstances. Computational Fluid Dynamics (CFD) comes to the rescue in such a case. Many engineers in the CFD course in India begin their journey by learning how simulations solve real-world challenges without costly experimentation.
ansys
An Introduction to CFD and ANSYS Fluent CFD​
Computational Fluid Dynamics, or CFD, was a well-established science during the latter part of the 20th century. Originally developed for aerospace and defense applications, it soon found applications in many industries because it could simulate fluid flow, heat transfer, and chemical reactions on a computer.
CFD's versatility and richness are its strengths—it enables engineers to see and forecast fluid behavior, optimize process design, and solve problems with immense accuracy. One of the most widely used and potent tools available in the industry today is ANSYS Fluent CFD, a software tool that allows engineers to simulate fluid dynamics and heat transfer problems with intricate detail, including multifaceted multiphase flow systems.
Today, enrolling in an ANSYS Fluent course in India helps aspiring engineers gain this expertise. Many universities and institutes also promote CFD coaching to prepare students for real-world engineering applications
But early CFD was not as readily available. During the 1980s and even into the early 1990s, the industry application of CFD was not common due to the expense of computing and a lack of adequate hardware. Simulations were time-consuming and required specialised computing facilities.
But all this changed during the last two decades.
The Emergence of ANSYS Fluent CFD in Multiphase Flow Systems​
Because of the rapid advancement in computer hardware and software, CFD has become a standard engineering practice. These days, even highly complex systems like multiphase flows can be simulated and analysed with a high degree of detail and accuracy with the help of software like ANSYS Fluent CFD.
Multiphase flow refers to the concurrent flow of materials in two or more phases—typically blends of gas, liquid, and solids. Multiphase flow occurs in oil-gas mixtures in pipelines, steam-water interaction in boilers, and solid-liquid slurries in chemical reactors.
To simulate such intricate flows, modern CFD software packages have various multiphase models each tailored for specific flow situations. ANSYS Fluent CFD has robust modeling of various flow regimes with efficient and accurate solutions. Some models model one of the phases as a dispersed phase, while some model interfacial interactions more realistically. The choice of the correct model depends on the flow regime, relative phase densities, and the task of the simulation.
Case in Point: Horizontal Gas-Liquid Flow in Pipelines​
In horizontal pipes, two-phase flow of gas-liquid is especially difficult to analyze because, due to the effect of gravity in a direction perpendicular to the flow, the phases get separated, and the number of flow patterns possible is increased.
There are six main regimes of flow characteristic to horizontal gas-liquid systems:
AD_4nXeUYvmktlm3_WOJ--mNArxjXGMwpXvYiR14h3rvjQzDo4W-Ea9oGzEhBwYFkqr8pQ4oVfSjgVS45sjQSZqE_fkNe9vRHUtdw0wGWolH1hthGrZVwTvTYDVx866s9_LzGgwS0HZaww
1. Stratified Flow​
Occurs under low gas and liquid velocities. Liquid and gas phases are fully separated with a level interface. Liquid flows at the pipe bottom, and gas flows above it.
2. Bubble Flow​
Occurs when gas bubbles are distributed in a continuous liquid phase. This will usually happen in high liquid velocity and low gas velocity situations. This will have a similar appearance to the bubble flow commonly observed in vertical pipes.
3. Wavy Flow​
Occurs when the velocity of the gas increases in a stratified system. The gas-liquid interface begins to develop waves, and these waves grow, affecting momentum transfer between phases.
4. Slug Flow​
More dynamic regime, in which a column of liquid is displaced by large gas bubbles. Alternating slugs of gas and liquid flow intermittently.
5. Annular Flow​
In this condition, liquid coats the pipe walls, and gas travels inside the pipe core. Annular flow is generally experienced at high gas flow rates.
6. Dispersed Flow​
At extremely high velocities, where liquid and gas phases are well mixed, phases do not possess definite boundaries.
Each of these regimes separately has a certain effect on pressure drop, heat transfer, and mass transfer behavior, requiring their proper prediction for pipeline design and safe operation. ANSYS Fluent CFD has flow regime maps and phase interaction models for the efficient prediction and control of these patterns by engineers.
The Future of CFD in the Oil & Gas Industry​
With increasing needs for cleaner energy, improved resource efficiency, and production, the need for precise modelling and simulation has never been more important. CFD software is accelerating at a fast pace to integrate artificial intelligence, machine learning, and cloud computing to further encourage simulation. Additionally, data-driven modeling, digital twins, and real-time simulation have the potential to transform the operation and design of multiphase flow systems by engineers. All of these are expected to be safer, save time, and cut energy expenses substantially. ANSYS Fluent CFD is also combining advanced solvers and automation technologies to enable these next-generation applications, and is thus a pillar of engineering analysis innovation.
Final Thoughts​
In summary, multiphase flow analysis is an integral part of the design and operation of many systems, especially in the oil and gas industry. Through the observation by ANSYS Fluent CFD, engineers can achieve unprecedented levels of comprehension of such complex systems, paving the way to innovation, maximising efficiency, and driving the industry ahead. Whereas CFD was previously the domain of specialist researchers, today it is a core tool in the possession of industry experts. And as the technology improves, so will our capacity for simulation, understanding, and optimising the main processes that drive our world.
Learn ANSYS Fluent CFD with PIGSO LEARNING​
Want to build hands-on skills in multiphase flow simulation and process modelling using ANSYS Fluent CFD? Join our comprehensive ANSYS Fluent CFD Online Course at PIGSO LEARNING.
Whether you're a student, researcher, or industry professional, our course will equip you with practical knowledge, real-world project experience, and the confidence to simulate complex fluid systems. Start your computational fluid dynamics training course journey today with structured CFD coaching and transform your understanding into industrial expertise. Our ANSYS Fluent course in India combines academic depth with practical industry application
Enrol Now and take your engineering career to the next level
