  • LOUNGE
  • MCQ Questions
  • Reinforced Concrete - MCQ
  • Thread starter Thread starter Srinivasan
  • Start date Start date Feb 9, 2018
Srinivasan
Srinivasan
Prime CE
mumbai
  • Feb 9, 2018
(A) Modular ratio method
(B) Load factor method
(C) Ultimate load method
(D) None of these
Answer: Option A
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Jun 6, 2019
Ayuba
Ayuba
Srinivasan
  • Srinivasan
  • Feb 9, 2018
Feb 9, 2018
Srinivasan
Srinivasan
Srinivasan
  • Srinivasan
  • Feb 8, 2018
Feb 8, 2018
Srinivasan
Srinivasan
Srinivasan
The minimum number of main steel bars provided in R.C.C.
  • Srinivasan
  • Feb 8, 2018
Jun 27, 2020
rahuledu
R
