Activities For Plumbing Network
Underground Plumbing Activities
-Underground piping
-Putting sleeves in concrete slabs
-Embedded pipes in concrete slabs
First Fix Plumbing Activities
-Cutting and chasing in the block wall
-Putting pipes in the block wall
Second Fix Plumbing Activities (Typical Floor In Tower)
-Horizontal drainage piping
-Horizontal water supply piping
-Vertical Water supply pipes (Riser)
-Vertical drainage pipes (Riser)
-Floor Drain (Trap)
-Water Heater Installation
-Shower Tray/ Bath Tub Installation
Second Fix Plumbing Activities (Basement/Mechanical
Floor/Roof)
-Sewage Lift Pump Installation and Piping
-Water Transfer Pump Installation and Piping
-Water booster pump Installation and Piping
-Installation Of Water Tank and connection
Final Fix Plumbing Activities
-Sanitary Ware Installation
-Installation of Water Meter
Testing and Pre-Commissioning
-Pre-Commissioning Of Water Transfer and Booster pumps
- Pre-Commissioning Of Water heater
-Roof Water Tank Fillup
-Flushing and checking leaks in water supply pipes
-Flushing and checking leaks in drainage pipes
-Flow test on drainage
Commissiong & Handing Over
-Testing and Commissioning Of Water Transfer and Booster pumps
-Testing and Commissioning Of Water heater
-Testing and Commissioning Of bathtub and sanitary ware
