Advice regarding core cutting in RC wall
Hello everyone,
I am a home owner having a flat on 14th floor of a building which has total 16 floors. Building walls are made of RCC.
I am doing some renovation in my home.
I need advise on whether it is ok to cut a hole of size 5 inches in the RCC wall for chimney pipe ? if yes what precautions should be taken to avoid any damage to the overall wall structure ?
Any advice regarding this will be helpful.
thanks,
Nitin
1. Check if the wall is structural or non-structural
  • Structural walls (shear walls, load-bearing walls, core walls): Never cut or drill large holes without structural engineer approval. Even a small 5-inch hole can damage reinforcement bars or weaken the wall.
  • Partition walls (non-load-bearing infill or block walls): Usually safer to cut, but still requires caution.
👉 First, confirm with the building’s structural drawings (or consult the builder/society/structural engineer) whether your wall is structural.
2. Risks of cutting RCC walls​
  • You may cut through steel reinforcement bars, reducing strength.
  • Could cause cracks that spread over time.
  • May reduce the fire resistance of the wall.
  • In extreme cases, it could compromise structural stability, especially in earthquake zones.
3. Safer alternatives​
  • Look for existing ducts, shafts, or openings provided by the builder for services (chimney, exhaust, AC pipes).
  • Use window-based chimney/exhaust outlet instead of cutting the RCC wall.
  • If possible, route the chimney pipe through non-structural walls.
4. If cutting is unavoidable
  • Get approval from your housing society / builder / structural engineer.
  • Use core-cutting (diamond core drill), not hammering, to avoid vibrations and cracks.
  • Position the hole carefully to avoid reinforcement bars (you can scan the wall with a rebar detector or use building drawings).
  • Keep the hole as small as possible (5 inches is already quite large).
  • Seal around the pipe with proper fire-resistant material after installation.
