Bill of Quantities (BOQ) for Site Grading - Protection Works
Sumit Civil
Well-Known Member
Attached herewith in excel file, it contains details of following;
Earthwork
Excavation by mechanical means (using JCB / Poclains/backhow , by bucket only etc) in all kinds of soil
Excavation by mechanical means (using JCB / Poclains/backhow, by ripper only etc) in all kinds of soft rock & weathered rock
Excavation in hard rock / boulders by controlled open blasting
Excavation in hard rock / boulders by controlled covered blasting
Excavation in hard rock / boulders by uncontrolled blasting
Excavation in hard rock / boulders by pneumatic breaker / chiselling
Filling and banking with approved good quality earth from the borrow area
Supply , place in position to required gradient about 230 mm thk but not less than 200 mm thick compacted dry rubble pitching
Supply & Fixing of high Strength Steel Wire Ropenet (Garware, meccaferi or equivalent) for boulderfall protection
Supply & Fixing of Galvanised Steel wire chainlink mesh (GARWARE & MECCAFERI or equivalent)
Providing and fixing of Geo-Fabric mesh over the prepared surface below
Providing and installing Rock Bolts/Anchors (Hilti make or eqivalent) of 25 mm diameter
Proving,Supplying,Placement of Rubble/ boulders inside Gabions
Providing and laying rubble soling OF 230 MM THK Min. 200 mm
Supplying, installation and fixing seepage drill holes
Providing and laying Geo-Grid of approved quality including cost of reinforcing elements material cost
Structural Works
Concrete Works
Providing, machine mixing and laying nominal mix, Plain Cement Concrete (PCC) M -10
Providing, machine mixing and laying nominal mix, Plum Concrete of M15 Design Grade optional i.e. by R.M.C. or by 7/10 Concrete batch
Providing and laying design mix grade M25 reinforced cement concrete with minimum cement content by R.M.C only for reinforced concrete work
Providing and laying design mix grade M30 reinforced cement concrete with minimum cement content by R.M.C only for reinforced concrete work
Reinforcement Works
Providing and placing reinforcement, in reinforced concrete work
Miscellaneous works
Provinding and applying the cement base paint
Cutting and Removal of trees roots of girth more than 300 mm
Providing and pacing 50 mm thick grass turfing of approved variety
Razing / Dismantling of the Reinforced cement Concrete / Plain cement concrete work/structure
Providing and constructing Random Rubble Masonry
Providing guiniting in two layer each of 75 mm thickness
Providing and fixing weldmesh jali 75 mm x 75 mm and 10 gauge thick
Supplying and installing ribbed PVC water stoppers
Supplying and installing and fixing 150 mm dia PVC pipes (finolex/Supreme/Prince 4kg/cm2)
Providing and laying the COCO erosion blanket
  • Bill of Quantities (BOQ) for Site Grading - Protection Works.xlsx
Reactions: joeadonoo
