Button Function on keyboard
Ctrl + A : Select All
Ctrl + B: bold
Ctrl + C: copy
Ctrl + D: font
Ctrl + E : Center Alignment
Ctrl + F : Find
Ctrl + G: go to
Ctrl + H : Replace
Ctrl + I : Italic
Ctrl + J : Justify Alignment
Ctrl + K: insert hyperlinks
Ctrl + L : Left Alignment
Ctrl + M: Incrase indent
Ctrl + n: new
Ctrl + O: open
Ctrl + P: Print
⌨Ctrl + Q: normal style
⌨Ctrl + R : Right Alignment
⌨Ctrl + S : Save / Save As
⌨Ctrl + T : Hanging Indent
⌨Ctrl + U : Underline
⌨Ctrl + V: Paste
⌨Ctrl + w: close
⌨Ctrl + x: cut
⌨Ctrl + Y: redo
⌨Ctrl + Z: undo
⌨Ctrl + 1 : Single Spacing
⌨Ctrl + 2 : Double Spacing
⌨Ctrl + 5 : 1,5 lines
⌨Ctrl + ESC: start menu
⌨F1: running the help function provided on word
⌨F2: altering name a file / folder
⌨F3: running orders command
⌨F4: repeating previous orders
Ann: running search and replace command or goto
⌨F6.: running other command pane
⌨F7: memeriksaan typos and text spelling (spelling)
⌨F8: the beginning of the highlight / selection of text or
object
⌨F9 : Mengupdate Field (Mail Merge)
⌨F10: enable menu
⌨F11: entering the next field (mail merge)
⌨F12: activating the us save dialog
⌨ESC: cancel dialogue / command
⌨Enter: perform an option or end a paragraph
⌨Tab: move text according to the existing tab tags on
horizontal ruler
⌨Windows: Mengktifkan start menu
⌨Shortcut: activating shortcut at cursor position
⌨Delete: Remove 1 characters on the right of the cursor
⌨Backspace: Removing 1 characters on the left of the
cursor
⌨Insert: Menyisip character in cursor position
⌨Home: move cursor position to the beginning of the line
⌨End: move cursor position to end of line
⌨Page Up: Roll the screen up
⌨Page Down: Roll the screen down
⌨Up: MOVE CURSOR 1 line up
Down: MOVE CURSOR 1 line down
⌨Left: MOVING CURSOR 1 characters to left
⌨Right: MOVE THE CURSOR 1 characters to the right
⌨Num Lock on: function typing numbers and active math
operators
⌨NUM LOCK OFF: Active Navigation button function
⌨Shift + F10: open the shortcut, just like clicking right
⌨Alt: button emphasis that is not combined with other
buttons only
Work to enable or start using bar menu
⌨Shift + Delete: delete selected items permanently
without placing items
In Recycle bin
⌨Ctrl + Right Arrow: move the insertion point to the
beginning of the next word
⌨Ctrl + Left Arrow: move the insertion point to the
beginning of the previous word
Ctrl + Down Arrow: move the insertion point to the
beginning of the next paragraph
⌨Ctrl + Up Arrow: move the insertion point to the
beginning of the previous paragraph
⌨Alt + F4: close active items, or log out of active
programs
⌨Alt + Enter: displaying properties from selected objects
⌨Alt + Spacebar: open the shortcut menu for active
windows
⌨Ctrl + F4: close active documents in programs that
allow you To have some open documents simultaneously
⌨Alt + Tab: switch between open items
⌨Alt + ESC: cycle through items in an open order
⌨Ctrl + shift + Tab: move backwards through tabs
⌨Shift + Tab: move backwards through options
Version 2:
• ⌨Ctrl + C (copy)
• ⌨Ctrl+X (cut)
• ⌨Ctrl+V (Paste)
• ⌨Ctrl+Z (undo)
• ⌨Delete (delete)
• ⌨Shift+Delete (delete selected items permanently
without putting items in recycle bin)
• ⌨Ctrl while dragging (Men-drag) an item (copying
selected items)
• ⌨Ctrl + shift while dragging items (make shortcuts to
selected items)
• ⌨F2 Button (change the name of the selected item)
• ⌨Ctrl + Right Arrow (move the insertion point (Cursor)
to the beginning of the next word)
• ⌨Ctrl + Left Arrow (move the insertion point (Cursor) to
the beginning of the previous word)
• ⌨Ctrl + Down Arrow (move the insertion point (Cursor)
to the beginning of the next paragraph)
•⌨ Ctrl + Up Arrow (move the insertion point (Cursor) to
the beginning of the previous paragraph)
• ⌨Ctrl + shift with one of the arrow key (highlight text
block)
• ⌨Shift with one of the arrow key
(Select more than one item in a window or on desktop, or
select text in document)
•⌨ Ctrl + a (Select all)
• ⌨F3 Button (looking for a file or folder)
• ⌨Alt + Enter (view properties for selected items)
• ⌨Alt + F4 (closing active items, or out of active
programs)
• ⌨Alt + Enter (display properties from selected objects)
• ⌨Alt + Spacebar (Open Shortcut Menu for active
windows)
• ⌨Ctrl + F4 (closing active documents in programs that
allow you to have some open documents simultaneously)
• ⌨Alt + Tab (switch between open items)
• ⌨Alt + ESC (cycle through items in an open order)
• ⌨The F6. Button (cycle through the screen elements in
the window or on desktop)
• ⌨F4 Button (featuring address bar list on my computer
or windows explorer)
• ⌨Shift + F10 (Featuring Shortcut Menu for selected
items)
• ⌨Alt + Spacebar (system menu display for active
windows)
•⌨ Ctrl + ESC (featuring start menu)
• ⌨Alt + underlined letter in menu name (display the
appropriate menu)
• ⌨underlined letter in the name of the command on the
open menu (do the appropriate command)
• ⌨Button Button (enable bar menu in active program)
• ⌨Arrow (open the next menu to the right, or open the
submenu)
• ⌨Left Arrow (open the left menu, or close the submenu)
• ⌨Ann Button (updating active windows or refreshing)
• ⌨Backspace (see folder one level up on my computer
• ⌨ESC (cancel duty now)
•⌨ Shift when you enter a CD-Rom into a CD-ROM
(Prevent CD-Rom automatically playing / autoplay)
Keyboard Shortcuts Dialog Box
• ⌨Ctrl + Tab (move forward through tab)
• ⌨Ctrl + shift + Tab (move backwards through tab)
• ⌨Tab (move forward through options)
•⌨ Shift + Tab (move backwards through choice)
• ⌨Alt + underlined letters (do the appropriate command
or choose the appropriate option)
• ⌨Enter (do command for option or active button)
• ⌨Spacebar (select or remove the checkbox if an active
option is check box)
• ⌨Arrow Tombols Arrow (Select a button if an active
option is a selection button group)
• ⌨F1 Button (featuring help)
• ⌨F4 Button (showing items in active lists)
• ⌨Backspace (open folder one level to the top if the
folder is selected in save as or open the dialog box)
Microsoft Natural Tombolboard Shortcuts
• ⌨Windows Logo (featuring or hiding the start menu)
• ⌨Windows Logo + Break (Featuring System Properties
dialog box)
• ⌨Windows Logo + D (featuring the desktop)
•⌨ Windows Logo + M (minimize all windows)
• ⌨Windows Logo + shift + M (restore minimized
window)
• ⌨Windows Logo + E (open my computer)
• ⌨Windows Logo + F (search for a file or folder)
• ⌨Ctrl + Windows Logo + F (search for computer)
• ⌨Windows Logo + F1 (featuring windows help)
• ⌨Windows Logo + L (Lock Keyboard)
• ⌨Windows Logo + R (open the run dialog box)
• ⌨Windows Logo + U (Open Utility Manager)
Accessibility Tombol board Shortcuts
• ⌨Right shift for eight seconds (switch filtertombols on
or off)
•⌨ LEFT ALT + LEFT SHIFT + PRINT SCREEN (Beralih
High Contrast on atau off)
• ⌨Left Alt + left shift + Num Lock (activate
mousetombols on or off)
• ⌨Shift five times (activate stickytombols on or off)
• ⌨Num Lock for five seconds (activate toggletombols on
or off)
Windows Explorer Tombolboard Shortcuts
• ⌨End (displaying the bottom of the active window)
• ⌨Home (showing the top of the active window)
• ⌨Num Lock + Asterisk Sign (*) (show all subfolders that
are under the selected folder)
• ⌨Num Lock + Plus Sign (+) (featuring content from the
selected folder)
• ⌨Num Lock + minus sign (-) (collapse selected folder)
• ⌨Left Arrow (collapse current option if expanded, or
select main folder)
• ⌨Right Arrow (featuring current selection, or select the
first subfolders)
Shortcut Tombols for character map shortcut for character
map
• ⌨Once you click twice on the character character grid,
you can move through the grid by using the shortcut Shortcut:
• ⌨Right Arrow (move to the right or to the beginning of
the next line)
• ⌨Left Arrow (move to the left or to the end of the
previous line)
• ⌨Up Arrow (move to top one line)
• ⌨Down Arrow (move down one line)
• ⌨Page Up (move to top one screen at a time)
• ⌨Down (move down one screen at a time)
• ⌨Home (move to early line)
•⌨ End (move to end line)
• ⌨Ctrl + Home (move to first character)
• ⌨Ctrl + End (move to last character)
• ⌨Spacebar (switch between the bigger and normal
when a character is selected)
Microsoft Management Console (MMC) Main Window Tombol
board Shortcuts
• ⌨Ctrl + O (open that saved console)
• ⌨Ctrl + N (open new console)
• ⌨CTRL + S (Save the open console)
• ⌨Ctrl + M (add or remove console items)
• ⌨Ctrl + W (open new window)
• Ann Button (content update from all console windows)
•⌨ Alt + Spacebar (featuring mmc window menu)
•⌨ ALT + F4 (Close the console)
• ⌨Alt + a (display the action menu)
• ⌨Alt + V (featuring the view menu)
• ⌨Alt + F (featuring the menu file)
• ⌨Alt + O (featuring the favourites menu)
Console mmc window tombolboard shortcuts
•⌨ Ctrl + P (Print Active page or active pane)
•⌨ Alt + minus sign (-) (featuring an active console
window window)
• ⌨Shift + F10 (featuring the action menu shortcut for
selected items)
•⌨ F1 Button (open the help topic, if any, for selected
items)
• ⌨Ctrl + F10 (Maximize Active Console Windows)
• ⌨Ctrl + Ann (Restore Active Console Window)
• ⌨Alt + Enter (display the properties dialog box, if any,
for selected items)
•⌨ Ctrl + F4 (close the active console window. When a
console has only one console window, this shortcut will close
the console)
Remote Desktop Connection Navigation
• ⌨CTRL+ALT+END (Open the m*cro$oft Windows NT
Security dialog box
• ⌨Alt + page up (switch between program from left to
right)
• ⌨Alt + page down (switch between program from right
to left)
• ⌨Alt + Insert (cycle through programs last used)
• ⌨Alt + Home (featuring start menu)
• ⌨Ctrl + Alt + Break (switch client computer between
windows and full screen)
• ⌨Alt+Delete (featuring the windows menu) Alt + Delete
• ⌨Ctrl + Alt + minus sign (-) (creating a snapshot of the
client's active window on the terminal server clipboard and
provides the same function by pressing screen print on a local
computer. )
• ⌨Ctrl + Alt + Plus Sign (+) (create a snapshot of the
entire client window area on the terminal server clipboard and
provide the same function by pressing alt + print screen on
local computers. )
Internet Explorer Navigation Internet Explorer navigation
•⌨ Ctrl + B (open favorite set dialog box)
• ⌨CTRL + E (Open the select bar)
• ⌨CTRL + F (Start the Find utility)
• ⌨CTRL + H (Open the History bar)
•⌨ CTRL + I (Open the Favorites bar)
• ⌨Ctrl + L (open open dialog box)
• ⌨Ctrl + N (start another example of a browser with the
same web address)
• ⌨Ctrl + O (open dialog box, just like ctrl + L)
• ⌨Ctrl + P (Open Print dialog box)
• ⌨Ctrl + R (updating this web page)
• ⌨Ctrl + W (close window active)
• Prin Scrn + Active Printer (Printing Snapshot / overall
window)
• ⌨Alt + Print Scrn + Smart Active (Printing Windows
Active)
• ⌨Shift + F3 (1 x) (Capital front letter)
• ⌨Shift + F3 (2 x) (all uppercase / big letters)
•⌨Shift + F3 (3 x) (all small letters)
Ctrl + B: bold
Ctrl + C: copy
Ctrl + D: font
Ctrl + F : Find
Ctrl + G: go to
Ctrl + H : Replace
Ctrl + I : Italic
Ctrl + n: new
Ctrl + O: open
Ctrl + P: Print
⌨Ctrl + V: Paste
⌨Ctrl + w: close
⌨Ctrl + x: cut
⌨Ctrl + Y: redo
⌨Ctrl + Z: undo
object
⌨F10: enable menu
horizontal ruler
cursor
operators
buttons only
In Recycle bin
programs
windows
Version 2:
• ⌨Ctrl + C (copy)
• ⌨Ctrl+X (cut)
• ⌨Ctrl+V (Paste)
• ⌨Ctrl+Z (undo)
• ⌨Delete (delete)
selected items)
selected items)
block)
programs)
windows)
items)
windows)
appropriate menu)
submenu)
dialog box)
window)
or off)
or off)
selected folder)
select main folder)
first subfolders)
map
the next line)
previous line)
board Shortcuts
window window)
selected items)
items)
for selected items)
the console)
Security dialog box
right)
to left)
computer. )
local computers. )
same web address)
window)
Active)
