Check List for Concrete Repair Works
Checklist for concrete repair works consist of following points;
checklist is a important record it helps us in order to get work done correctly and it ensure we do not miss any point to check which is important from aspect of Quality of work.
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed check list for concrete repair works
- Surface preparation done as per TDS and the approved methodology
- Application of Epoxy bond coat as per TDS
- Non-shrink Polymer modified mortar prepared and applied as per TDS
- Socket grouting done properly as per the approved method.
- Plugging of sockets done after grouting
- Surface finish of the repair works
- Sprinkling / moist Curing for 7 Days / as specified by manufacturer
- If NDT done, results are O.K?
