Check List For Electrical Installation Works at various phases of construction
Check List For Electrical Installation consist of following points;
Prior to Concreting
  • Make and size of Conduits
  • Location and Nos. of Outlets
  • Location of Switches Boxes
  • Location of Drops in Beams
  • Reference Drawing No.
  • Any Special Requirements
  • Eg. ( Changes by Clients)
  • All Switch Boxes/Conduits Covered / Plugged
After Brick Work
  • Conduits Chase in Walls
  • Location & Sizes of Switch Boxes etc.
  • All Switch Boxes / Conduits Plugged
Wiring (Electrical, T.V., Tel etc)
  • Make and Size of Wire
  • Check Colour Coding
  • No. of Wires at each point & Looping Arrangements
  • Extra Length of Wire at each Point
  • All terminations Checked
Switches etc.
  • Make/Type and Colour of Switch Cover Plates
  • Type of Switch/Socket
  • Type of Switch / Socket
  • Terminations
  • Cover Plate Fixing – appearance
  • Earthing
  • Check Controls / Operations
  • Cleaning
Distribution Box
  • Size and Make of D.B.s
  • No. & Ratings of MCB/RCCB/ELCB etc.
  • Incoming Cable Size
  • Cable & Wire Terminations
  • Earthing
  • Check Connection, Controls & Operations
  • Finish around DB
  • Cleaning Inside and Around DB
Kindly use it as reference document only to create Checklist. You are free to modify edit, delete add any content in it and use it as per your requirement. find enclosed herewith the detailed check list for electrical installation works at various phases of construction.
  • Checklist for electrical installation.doc
Reactions: Anant Mishra
